sofoco tools v12 is not working with bricscad 12.1.20 version
hello all,
sofoco tools v12 is not working with latest bricscad 12.1.20 version. is there any workaround or solution or patch for this?
  • From Sofoco tools I'm using "Mtext these text" and it works here.
  •  Hi Kotesh.  What exactly is not working?
  • i am not getting sofoco toolbars on the existing toolbars. even no floating toolbars. if i right click on toolbar, sofoco tools toolbar option is available with earlier bricscad versions.
  • Here is working fine - bricscad 12.1.20 version
  • If I understand well, try just (re)load PARTIAL cui file sofoco.cui file to Bricscad direct Customize (command CUI).
    You find it at (in my case): c:\Program Files (x86)\Sofoco\SofocoToolsV12\SofocoTools.cui
  • after restarting the system, sofoco tools start working. thanks for your help.
