V13.1.8 crashes when save
Has anyone encounter crashes during save with 13.1.8?
This is the crash report I got. This happened on a single user and I cannot reproduce it on other machines....
Does anyone has an idea?
  • I just upgraded from V12 to V13.1.8, and I had 2 crashes after a couple of hours use.  Mine produced a similar crash report, but the crashes occurred during drawing editing.  The drawing is very small, 2D only.  You should post your crash report to support, Emanuel.  I am going to put in a support request for mine.  There seems to be a problem they'll have to investigate.
  • Hi David,
    I don't know if this is going to solve your crash problem as well but here is something you may want to read and try. I was able to fix a switch layouts crash in BricsCAD 13.1.8 simply by re-installing BricsCAD with "Run as Administrator".
    More info here:
    http://rakeshrao.typepad.com/work_smarter_geotools/2012/11/tip-install-bricscad-as-an-administrator.html
    There is also a Lisp garbage collection bug in 13.1.8 to watch out for.
    Regards
    Rakesh Rao
    www.coordsys.com
  • Nope, reinstalling BricsCAD did not helped. I will do a SR but honestlly I do not have too much hope out of that.
