Syntax default.pgp
While trying to port some things from AutoCAD to BricsCAD I ran into the a problem. BricsCAD doesn't seem to like the lines starting with PLAYOUT in default.pgp:
NOTEPAD, START NOTEPAD, 1, *File to edit: ,
PLAYOUT1, CADCHUP.EXE PLAYOUT1, 4,,
PLAYOUT2, CADCHUP.EXE PLAYOUT2, 4,,
SH, , 1, *OS Command: ,
The result is the default.pgp defaults indeed, killing all settings and presenting a new - out of the box - default.pgp. So I learned to make a backup.
Bottom line is that I really need this line to work, it should pause BricsCAD (value 4), runs cadchup.exe with argument playout[1|2] and after finishing resumes BricsCAD running the rest of the commands under the button.
Being more precise: cadchup.exe generates is script which is fed back to BricsCAD, a menu item looks like
[_Button("PLAYOUT Paper Setup", "004.bmp", "004.bmp")]^C^Cplayout1;script;playout1.scr;playout2;script;playout2.scr;
Any suggestions on how to make this working?
