PDF export - all layouts without model space?
in Linux
I often use PDF export through EXPORT command. When I set up all layouts to export (PdfLayoutsToExport =1), all of the layouts are exported including model space. Is there a way to exclude model space, so that only layouts would be exported? I didn't find any way in BricsCAD, I use pdftk to remove the first page of exported PDF as a workaround.
TOm
TOm
Hello Tom,The publish command probably does what you want.
- select "PDF" in the "Publish to:" field
- remove the model space from the sheet list (select it and use the remove icon at top right of the list)
- choose "One Multi-sheet file" in the "File:" field of the publish options
- choose output location and name in the publish options
RegardsTijs0 -
Hi Tijs,
this is great news for me! I didn't know you could use internal PDF export with the Publish command. This enables much more than what I wanted. I still get error when publishing in background, but otherwise it works as intended.
Thank you very much,
Tom0
