Bricscad Communicator V15 failed to import stp/step files
Hello,
When i try to import simple stp files with bricscad it says 'cannot open file'. (communicator v15 also installed with license)
Solidworks (sldprt/sdasm) files work fine but we bought a license so we can import step files.
Anybody know why ?
The 2 files are attached, they have been created with Solidworks 2014 AP203 & AP214
For the record, I've been having the same issue with STEP files using BricsCAD V14.2.17 and Communictor V14. I filed a support request a few weeks ago, but Bricsys hasn't reacted.
I just downloaded your STEP files, and they didn't open with V14 either. I think Communicator was just ported over to V15, and no change or bug fixes were made. -
I face the same problem.Cannot open step file. Telling me something about missing right or license.This happens with BricsCad Window and Mac Version V15Is there meanwhile a solution?Uli
For what it's worth, I was able to import both 1.stp and 2.step using BC 15.2.08 and Communicator 15.2.02 and the objects come through fine.
I've been using STP import for a while. Molex is very generous in making STP models of many of their connectors available via Digikey. Haven't had a problem with any of them, yet.
Howdy, Stranger!
