Basepoint option of INSERT command
The basepoint option of INSERT command is not yet supported, this option is very useful (especially for developers) to redefine an insertion point "at fly".
Example in AutoCAD
Command: -INSERT
Enter block name or [?]: ~
Units: Unitless Conversion: 1.0000
Specify insertion point or [Basepoint/Scale/X/Y/Z/Rotate]: B
Specify base point:
Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>:
Enter Y scale factor :
Specify rotation angle <0>:
Example in BricsCAD
: -INSERT
? to list blocks in drawing/~ to open the file dialog/: ~
Multiple blocks/Scale/:
Corner/XYZ/X scale factor <1.000000>:
Y scale factor: < Equal to X scale (1.000000)>:
Rotation angle for block <0>:
It would be apreciate if you introduce this option in next releases.
Hi Francesco,Please file issues as a support request (separate request per issue), so our technical team can assist in a structured way.Thanks.mark0
Hi Francesco,Please file issues as a support request (separate request per issue), so our technical team can assist in a structured way.Thanks.markOk Mark I'm just doing it.0
