To run Visual Basic, you will have to install VBA6.
I can't run a macro under Windows7, using VBA in BricsCad Intellicad.
I have VBA6 in C:\Program Files\Common Files\microsoft shared\VBA\VBA6\VBE6.dll
I once managed to install Windows7 Bricscad 4 and running VBA, but now no longer manage.
In the comparison table you can find that VBA only works on 32 bit Windows. Maybe you are working with a 64 bit system? If you are working with a 32 bit system and can't get VBA to work you should send in a support request.
My windows is on 32 biti.
Howdy, Stranger!
