Automatic backup files sv4
in Linux
does Bricscad under linux save autoamtic backup files sv$ in certain time periods? I wasn't able to find any mention in BricsCAD onlin help (the search functionality there seems really bad to me). Nor did I find anything in settings. I can only find option to save/not save .bak files.
TOm
TOm
Not using Linux, but assuming (?) settings are the same as in Windows:
Settings / SaveTime Interval -
Hi Robt,
I found this too, but I didn't find path, where the saved files are. This will be different in linux.
TOm -
it should be SAVEFILEPATH ... usually pointing to the system's TEMP folder
many greetings ! -
Settings / Save File Path?
Oh. I should have found this by myslef - I was checking the /tmp directory and found no backup, becasue the SaveTime was set to 60 minutes. Now I tried to hcange it to 1 minute and I can find the backup file.
I thank both of you,
TOm
Howdy, Stranger!
