Block
Yesterday I started working on a large architectural lighting layout drawing received from an architect.
The entire ceiling is a 2' x 4' grid, and the lighting fixtures are 2' x 4' layins.
But as I received the drawing the grid and lighting fixtures were on the same layer!!!!
Being new to BricsCad I thought this will be easy. Just edit the 2' x 4' block lighting fixrture (called fluor) and
everything will be separate layers as I needed. But I could edit the block and change everything but layer.
I tried attredef command and still could not separate the layers.
So I created a new layer and used the (move to current layer command) and transferred the light fixture blocks
one by one to the new layer ???!!! This was a tedious process. There must be a better way. Please assist.
Thanks H. Hampton.
You can use QuickSelect to select entities that share the same property, e.g. all blocks of the same name.See the BricsCAD Help under User Guide / Modifying Entities / Selecting Entities / Using Quick Select.
Thanks.
Howdy, Stranger!
