When exporting a LAYOUT as a DWG, can the VIEW PORT clipping be retained? The base file has a complex 3D model and multiple paper-space drawings.
Our customer is demanding 2D drawings as individual scaled DWG files. The Export command of the Layout works OK. I then explode the dimensions, scale the entire drawing to full size, and delete unused layers. The only problem is that the Viewports extend beyond their borders.
