Export 2D DWG
When exporting a LAYOUT as a DWG, can the VIEW PORT clipping be retained? The base file has a complex 3D model and multiple paper-space drawings.
Our customer is demanding 2D drawings as individual scaled DWG files. The Export command of the Layout works OK. I then explode the dimensions, scale the entire drawing to full size, and delete unused layers. The only problem is that the Viewports extend beyond their borders.
Please cancel my question. My problem seems to have been a bad 3D model file. I copied the elements into a new DWG file, and LAYOUTEXPORT performs well.Dan S.
Howdy, Stranger!
