How to visualize 100% the x-references?
Dear friends,
How can i vusualize the xrefs completely? When i upload a new x-ref it appears to be screeened at 50% or so...
thanks
jm
XDWGFADECTL ?0
It worked!thanks Robt0
This question appears a lot, and caused me many hours of effort trying to solve. It also made myself and/or the BricsCAD program look like they weren't very good at producing drawings.Very few users can claim they understand as much as 99% of the features a very complex program, such as BricsCAD. In reality, we only learn a part of the features available The others are ideally out of the way, and don't intrude into the work flow.I am puzzled why this variable defaults to the 50% setting? Perhaps AutoCAD also does this, and so BricsCAD does it to maintain consistency But, I suspect that this default causes enough trouble, that even if AutoCAD defaults to 50%, that it would save the BricsCAD users a lot of grief if BricCAD would just default to 100% setting for this feature.By the way, I am still having ongoing issues with some items and some drawings being faded. This is even happening in drawings where I have attached all the Xrefs. If I set the print render style to be Legacy Hidden, the problem goes away, but that is not a good option for us, because I have a lot of round tubing, and square tubing with rounds at the corners. This style of rendering puts tessellation lines on those curves, resulting in an extremely thick line.I am still corresponding with tech support on this issue.-Joe0
Joe, try settings search xref and hit the down arrow 5 times. there seems to be 2 different fade settings. I never use xrefs but it seems lake a good start.
I could not find the other xref fade setting you were referring to. also, something I should have mentioned this when I posted, is that I am on v14.Also, I emphasize that the drawing with the problem no longer has any xrefs. They have been inserted as blocks now. Yet the problem persists.-Joe0
