Text File Also PDF question.
How do I insert a text file xxx.txt into a BricsCad cad file? Not as a PDF , but as a text file.
Also when I insert a PDF into a drawing, and plot the drawing as a PDF file, the inserted PDF shows up sometimes as a blank rectangle.
What might I being doing wrong?
Thanks H. Hampton.
Ad #1:
Use Rtexts:
http://www.b-k-g.nl/bkg_rtext.html
Or perhaps this alternative approach based on fields and Lisp variables:
http://forum.bricsys.com/discussion/28218 -
Ad #1:
Use Rtexts:
http://forum.bricsys.com/discussion/28218Thanks for your help. -
Thank you for your feedback. Regarding your second issue: I suggest sending in a support request.
Potentially your issue may be related to a bug. Currently the screen background colour will determine whether the PDF will print or not. Export to PDF is affected in the same way.
For Paperspace Layouts BKGCOLORPS = 7 (white) prints ok, BKGCOLORPS = 256 (black) doesn't.
For Model space BKGCOLOR = 7 (white) prints ok, BKGCOLOR = 256 (black) doesn't.
This issue has been reported in SR 69373.Regards,Jason Bourhill
Howdy, Stranger!
