Text File Also PDF question.
 How do I insert a text file    xxx.txt  into a BricsCad  cad file?    Not as a PDF , but as a text file.
Also when I insert a PDF into a drawing, and plot the drawing as a PDF file, the inserted PDF shows  up sometimes as a blank rectangle.
What might I being doing wrong?
Thanks  H. Hampton.
