Print Window
Is there a way to easily grab the Print Window dimensions?
I mainly use Paper Space, but preliminary work or very large projects where I just want a PDF to send on I often print from Model Space.
I'd like to be able to toggle/ switch to or similar, specific print window locations.
I can copy out the coordinates and put in a text file and then either load that or just paste end of line coordinates and select that, but wonder if there's a more direct route to same.
Thanks
Richard
Print with the View option? You can save multiple model space views in the drawing from which you can then print at any time.
Regards,Jason Bourhill
Thanks JasonDon't use views so hadn't thought about that.I'll amend my Cad habits.Appreciate the quick responseRichard0
