Print Window
 Is there a way to easily grab the Print Window dimensions?
I mainly use Paper Space, but preliminary work or very large projects where I just want a PDF to send on I often print from Model Space.
I'd like to be able to toggle/ switch to or similar, specific print window locations.
I can copy out the coordinates and put in a text file and then either load that or just paste end of line coordinates and select that, but wonder if there's a more direct route to same.
Thanks
Richard
  • Print with the View option? You can save multiple model space views in the drawing from which you can then print at any time.
    Regards,
    Jason Bourhill
  •  Thanks Jason
    Don't use views so hadn't thought about that.
    I'll amend my Cad habits.
    Appreciate the quick response
    Richard
