XREF absolute versus relative, no additonal tools needed>.
Simply enter xref
The drawing explorer starts.
Click on the saved path and set a point before the first /
Example:
Absolute path is Z:/company/aaa/bbb/ccc/ddd/xref/drawing.dwg
Click on it and set a point just before /xref
Then press enter an save the drawing. From then relative.
Works also under other cad applications.
this lisp function is what I use:[code];;;------------absolute to relative path----------------;IDEA IS TO GET RID OF PORTIONS OF PATH THAT MATCH, AND REPLACE FOLDERS THAT DO NOT WITH ..;NO CROSS DRIVES ALLOWED;IF PATH MATCHES, STRIP IT TO BARE FILENAME;(CONV-PATH-ABS-TO-REL "C:\\Storage\\Programming\\Lisp2\\PurgeIds2\\Development.dwg" "C:\\Storage\\Programming\\Lisp\\PurgeIds\\Development.dwg");GIVES "..\\..\\Lisp2\\PurgeIds2\\Development.dwg";(CONV-PATH-ABS-TO-REL "D:\\0001\\Engineering\\Base Files\\1E-OA_Project-CALC.dwg" "D:\\0001\\Engineering\\test1.dwg")(DEFUN CONV-PATH-ABS-TO-REL (CHG-FILENAME CUR-FILENAME / DWG_NAME N LAST_N DNAME XRELNAME DL);IF ON SAME DRIVE(COND;SAME PATHccf((= (STRCASE (vl-filename-directory CUR-FILENAME)) (STRCASE (vl-filename-directory CHG-FILENAME)))(SETQ xRELname (vl-filename-base CHG-FILENAME)) ;NAME ONLY);ON SAME DRIVE((= (STRCASE (SUBSTR CUR-FILENAME 1 1)) (STRCASE (SUBSTR CHG-FILENAME 1 1)))(SETQ n 1)(SETQ last_n 1);;;WHILE PREFIXS ARE SAME, KEEP TRACK OF INDEX(while (= (STRCASE (SUBSTR CUR-FILENAME n 1)) (STRCASE (SUBSTR CHG-FILENAME n 1)))(IF (= (SUBSTR CHG-FILENAME n 1) (chr 92))(SETQ last_n n))(SETQ n (1+ n)));NOW STRIP OUT AND ADD BACK STARTING AT N(SETQ dname (SUBSTR CUR-FILENAME (+ last_n 1))xRELname (SUBSTR CHG-FILENAME (+ last_n 1)))(SETQ dl (STRLEN CUR-FILENAME))(SETQ n 1)(REPEAT dl(IF (= (SUBSTR dname n 1) (chr 92))(SETQ xRELname (STRCAT ".." (chr 92) xRELname)))(SETQ n (1+ n))));NOT ON SAME DRIVE((/= (STRCASE (SUBSTR CUR-FILENAME 1 1)) (STRCASE (SUBSTR CHG-FILENAME 1 1)))(SETQ xRELname CHG-FILENAME) ;FULL PATH))xRELname)[/code]0
my gosh, looks like insert code adds a billion empty lines!Use this:;;;------------absolute to relative path----------------;IDEA IS TO GET RID OF PORTIONS OF PATH THAT MATCH, AND REPLACE FOLDERS THAT DO NOT WITH ..;NO CROSS DRIVES ALLOWED;IF PATH MATCHES, STRIP IT TO BARE FILENAME;(CONV-PATH-ABS-TO-REL "C:\\Storage\\Programming\\Lisp2\\PurgeIds2\\Development.dwg" "C:\\Storage\\Programming\\Lisp\\PurgeIds\\Development.dwg");GIVES "..\\..\\Lisp2\\PurgeIds2\\Development.dwg";(CONV-PATH-ABS-TO-REL "D:\\0001\\Engineering\\Base Files\\1E-OA_Project-CALC.dwg" "D:\\0001\\Engineering\\test1.dwg")(DEFUN CONV-PATH-ABS-TO-REL (CHG-FILENAME CUR-FILENAME / DWG_NAME N LAST_N DNAME XRELNAME DL);IF ON SAME DRIVE(COND;SAME PATHccf((= (STRCASE (vl-filename-directory CUR-FILENAME)) (STRCASE (vl-filename-directory CHG-FILENAME)))(SETQ xRELname (vl-filename-base CHG-FILENAME)) ;NAME ONLY);ON SAME DRIVE((= (STRCASE (SUBSTR CUR-FILENAME 1 1)) (STRCASE (SUBSTR CHG-FILENAME 1 1)))(SETQ n 1)(SETQ last_n 1);;;WHILE PREFIXS ARE SAME, KEEP TRACK OF INDEX(while (= (STRCASE (SUBSTR CUR-FILENAME n 1)) (STRCASE (SUBSTR CHG-FILENAME n 1)))(IF (= (SUBSTR CHG-FILENAME n 1) (chr 92))(SETQ last_n n))(SETQ n (1+ n)));NOW STRIP OUT AND ADD BACK STARTING AT N(SETQ dname (SUBSTR CUR-FILENAME (+ last_n 1))xRELname (SUBSTR CHG-FILENAME (+ last_n 1)))(SETQ dl (STRLEN CUR-FILENAME))(SETQ n 1)(REPEAT dl(IF (= (SUBSTR dname n 1) (chr 92))(SETQ xRELname (STRCAT ".." (chr 92) xRELname)))(SETQ n (1+ n))));NOT ON SAME DRIVE((/= (STRCASE (SUBSTR CUR-FILENAME 1 1)) (STRCASE (SUBSTR CHG-FILENAME 1 1)))(SETQ xRELname CHG-FILENAME) ;FULL PATH))xRELname)0
