Linetype loader for BricsCAD
I'm running and checking codes for compatibility.
One of which is a linetype loading device.
During loading this comes forward. What does it mean, where do i have look for?
; error : Automation Error 80020009; [IAcadLineTypes] Error accessing [LOAD] method. ErrIndex=0;
Undefined LineType
Is your file "RH-iso.lin" in a folder declared as support/search path ?
Please try
(findfile "RH-iso.lin")
should return the full filename ... but if NIL, then the file is not found.
many greetings !0 -
not nil, it is there allright.
Maybe a supporting .shx missing.0 -
Hello Hans,
can you open a support request for this, and add the small Lisp routine and your .lin file ? So we can investigate ...
many greetings !0 -
No need for that Torsten.
I'm running the classic BricsCAD version ..I must say, i like the clear feedback & messages from BricSCAD.
In AutoCAD i would use 'simulate' to run lisp and figure it out
_
"VBA is not included in your license.
Unable to recognize command "LOADLINETYPE.DVB!ACADPROJECT.MODULE1.RHISOLIN_LOAD". Please try again. "VBA is a pain in the butt anyway and i will have little remorse forgetting some lisps that rely on them
So many ways to get the get some linetypes in. "Lee Mac Steal" probably does a better job anyway!
My new linetype loader will be this
