Linetype loader for BricsCAD
Hi,
I'm running and checking codes for compatibility.
One of which is a linetype loading device.
During loading this comes forward. What does it mean, where do i have look for?
; error : Automation Error 80020009; [IAcadLineTypes] Error accessing [LOAD] method. ErrIndex=0;
Undefined LineType
  • Is your file "RH-iso.lin" in a folder declared as support/search path ?
    Please try
    (findfile "RH-iso.lin")
    should return the full filename ... but if NIL, then the file is not found.
    many greetings !
  • not nil, it is there allright.
    Maybe a supporting .shx missing.
  • Hello Hans,
    can you open a support request for this, and add the small Lisp routine and your .lin file ? So we can investigate ...
    many greetings !
  • Hans Lammerts
    edited June 2017
    No need for that Torsten.
    I'm running the classic BricsCAD version ..
    I must say, i like the clear feedback & messages from BricSCAD.
    In AutoCAD i would use 'simulate' to run lisp and figure it out
    _
    "VBA is not included in your license.
    Unable to recognize command "LOADLINETYPE.DVB!ACADPROJECT.MODULE1.RHISOLIN_LOAD". Please try again. "
    VBA is a pain in the butt anyway and i will have little remorse forgetting some lisps that rely on them
    So many ways to get the get some linetypes in. "Lee Mac Steal" probably does a better job anyway!
    My new linetype loader will be this :)
    http://www.lee-mac.com/steal.html
