List of Keyboard Shortcut
Can anyone advise me how to get it list of keyboard shortcut?
I mean shortcut + title + command.
To text file or something similar.
Thanks
The default shortcuts can be found in the (Online) Help. But you can create your own using the _Customize command.
I mean list.
On customize i have to highlight line with shortcut and look down at command.
See picture.It is very uncomfortable.
@Tom Foster:
Judging from the image the OP wants a list of his/her own custom shortcuts.0 -
Keyboard shortcuts are stored in the CUI.
Look for:
<AcceleratorRoot>
In CUI it is:
It is e bit confusing.0 -
If you enter command
_CUI
and then click on "LUKAS
", you'll see where your partial menu cui is located. Next you do is what Roy suggested. Does that solve it?0
