Preview image importing blocks very small
the preview image of my blocks is very small. How can I increase this image? (so some details are visible)
see attached screenshot
What you are seeing here is a pixel image of the last drawing view stored in the file. Before you saved these drawings (or created them using the _Wblock command) you should have zoomed in.
ok, thank you for your response.
Is there a LISP to zoom out all 3200+ blocks and save afterwards?
Try using BKG_Batch. The 'Zoom_Extents_Zoom_Scale_090.lsp' sample should do the trick.
Roy, thank you very much! A great tool.
@Roy Klein Gebbinck , do you know a lisp to change a layer from visible to invisible? (so I can use this with your programme to hide a layer)
I am glad you like it!
@Bas Weinans said:
@Roy Klein Gebbinck , do you know a lisp to change a layer from visible to invisible? (so I can use this with your programme to hide a layer)Example code to freeze a layer:
(setq layerName "MyLayer") ; Change the layer name to suit. (if (tblobjname "layer" layerName) (command "_.-layer" "_freeze" layerName "") ; Alternative: Use "_off" instead of "_freeze". ) (setq layerName nil)
Howdy, Stranger!
