Preview image importing blocks very small
Hi,
the preview image of my blocks is very small. How can I increase this image? (so some details are visible)
see attached screenshot
  • What you are seeing here is a pixel image of the last drawing view stored in the file. Before you saved these drawings (or created them using the _Wblock command) you should have zoomed in.
  • ok, thank you for your response.
    Is there a LISP to zoom out all 3200+ blocks and save afterwards?
  • Try using BKG_Batch. The 'Zoom_Extents_Zoom_Scale_090.lsp' sample should do the trick.
  • Bas Weinans
    edited August 2017
    Roy, thank you very much! A great tool.
    @Roy Klein Gebbinck , do you know a lisp to change a layer from visible to invisible? (so I can use this with your programme to hide a layer)
    I am glad you like it!
    Example code to freeze a layer:
    (setq layerName "MyLayer") ; Change the layer name to suit.
    (if (tblobjname "layer" layerName)
      (command "_.-layer" "_freeze" layerName "") ; Alternative: Use "_off" instead of "_freeze".
    (setq layerName nil)
