I just need to get a 2d dwg from a 3d drawing.
in 2D Drafting
The problem is that the model is not a solid.
Start here
https://blog.bricsys.com/tutorials/3d-direct-modeling-basic-commands/
Then here
https://blog.bricsys.com/tutorials/2d-drafting/copying-layouts-to-model-tab/Try extruding the profiles in the new file.
Patrik
I need a 2d entity for CAM purposes. A customer sent these files to us like this. I was able to get a 2d version by using "region" command and then exploded everything. I was then able to erase the 3d extruded face, leaving just the 2d top profile.Thanks for the tips!
You could have also used the _Boundary command.
