Automaticly settings on droving explorer when I opening a drawing
Hi I would like to set up in drawing explorer automaticly when I open a drawing:
- filters "xref"
- invert filter
See attached file.
I do it manualy again, again ...
How can do it BricsCAD automaticly?
You don't have to use a layer filter to achieve this. Try toggling the 'Show Xref Layers' option in the 'View' menu of the Drawing Explorer.
I'd like to avoid opening drawing explorer (interactive action - too slow).
How can I do it programaticly (namely: Layers/Filter = "XRef", Layer/Hide XRef Symbol = "Off", Layer/Invert Filter = "On"?) - see the picture.
I suppose this mean to access a dictionary (which one?) and/or modify one or more its values (bits) (which ones?).Any help would be appreciated.
Best regards,
Honza
I don't understand your objection to my suggestion. You would only have to do this once. The setting is stored for future sessions.
Howdy, Stranger!
