Automaticly settings on droving explorer when I opening a drawing
Hi I would like to set up in drawing explorer automaticly when I open a drawing:
  • filters "xref"
  • invert filter
    See attached file.
    I do it manualy again, again ...
How can do it BricsCAD automaticly?
  • You don't have to use a layer filter to achieve this. Try toggling the 'Show Xref Layers' option in the 'View' menu of the Drawing Explorer.
  • I'd like to avoid opening drawing explorer (interactive action - too slow).
    How can I do it programaticly (namely: Layers/Filter = "XRef", Layer/Hide XRef Symbol = "Off", Layer/Invert Filter = "On"?) - see the picture.
    I suppose this mean to access a dictionary (which one?) and/or modify one or more its values (bits) (which ones?).
    Any help would be appreciated.
    Best regards,
    Honza
  • I don't understand your objection to my suggestion. You would only have to do this once. The setting is stored for future sessions.
