How am I able to insert a JPEG or PDF into my title block template? (not raster image)
I am looking to insert permanently our company logo. How am I able to insert a JPEG or PDF into my title block template? (not raster image)
In Sofoco Tools, there is a tool called PolyPic. It can convert the pixels of a raster image into coloured polylines - stored in a block. This is fairly efficient depending on the complexity of your logo. It's free. http://www.sofoco.com.au/?q=node/25
@Damian Harkin: Good to know there is a tool.
@seanhenry356: A logo is coming back in every drawing and I tend to put some effort in it: Drawing, tracing an inserted image (IMAGEATTACH), by making closed polylines. So issuing a PLINE command, a start point and adding points while switching from L(ine) mode to A(rc) mode and vice versa, ending with a CL(ose) option. At the first arc point you may want to use option D(irection). Hope you are still here... It requires a bit of exercise to do it right. When all polylines are made you can hatch them with a solid pattern. This is an example I did a few years back: https://commons.wikimedia.org/wiki/File:Koninklijke_marechaussee.svg, all based on these principles.0
