Printing 3D objects?
I'm having a bit of trouble getting the results I want printing 3D objects.
Attached is the D size print out of Fixit PDF printer driver. It has worked fine in 2D drafting but something is going on with the 3D.
The objects are light, although I have it set to Black in BC and Blak & White in the printer driver.
The corners of the tube parts have radiused edges so any mode except HIDDEN produces heavy edges.
I always use qPrint, STB files,
Setting the Viewport itself to Visual Style: Hidden and
Shade plot to Wire Frame gives OK results but the border of the radiused edge is still too thick for my taste.
This is using a line weight of 0.09 mm0 -
This topic may be of interest:
https://forum.bricsys.com/discussion/29864/ongoing-saga-about-faded-model-space-objects-on-pdfs0
