Printing 3D objects?
I'm having a bit of trouble getting the results I want printing 3D objects.
Attached is the D size print out of Fixit PDF printer driver. It has worked fine in 2D drafting but something is going on with the 3D.
The objects are light, although I have it set to Black in BC and Blak & White in the printer driver.
The corners of the tube parts have radiused edges so any mode except HIDDEN produces heavy edges.
I always use qPrint, STB files,
