Definition of angels
Where/under which menue in settings is the precision after the decimal point for an angle set?
AUPREC
DIMADEC
Concerning "Definition of angels": https://en.wikipedia.org/wiki/Angel.
DIMADEC influences the DIMSTYLE value. More precise, DIMADEC is an override of a dimension style. While less easy, DIMSTYLE has the advantage of having all settings in one place (tab "Fit") and defined only once.
After looking for a location of DIMSTYLE in the menu, it was a bit surprising not to find it. It is also not available in the Dimension toolbar. On the other hand, command "D" or "DIMSTYLE" is a perfect shortcut to Drawing Explorer's dimension style section.
The -Dimstyle command, in 4 different variations, is at the bottom of the "Dim" pull-down menu and at the right end of the Dimensions toolbar.
