Tool for architects
Hello,
One of the most tools for architects is to put vertical dimensions on façade
like image
I never seen this in Bricscad
You think is possible to have on future southings like this?
Hello,
the vertical Dimension is a tool in our application for metal Engineering ( Windows / doors / curtain walls).http://www.syscad.org/help-en/kap7b_1.gif
If you only want to have a simple solution, please have a look into this german cad-forum:
http://forum.cad.de/foren/ubb/Forum54/HTML/023609.shtml
There are some dynamic blocks for that, the solution of SUSI79 (HoeheV2.dwg.txt rename it to HoeheV2.dwg) should also work in BricsCAD.
Regards
Wolfgang
You might be able to create a dimension style that looks like that, though to do so you might have to create a custom arrow block and maybe a custom linetype. Attached shows what I was able to do with just what's built-in. The dimstyle of the dimension entity on the right is a variation of the dimstyle of the one on the left, with these changes:
- Arrow 1 = None
- Arrow 2 = Datum triangle filled
- Dim line LW = 0.00 mm
- Dim line 1 = Off
- Dim line type = DOT
- Ext line 1 = Off
- Text rotation = 359
- Text movement = Move text, no leader
Also, the dimension entity's Linetype scale property is set very high. That, in combination with the 3 revised Dim line settings, makes the dimension line almost invisible. I don't know if it can be made completely invisible; perhaps with a custom linetype.
It is definitely not as fancy, but what is wrong with a new
_UCSand creating_DIMORDINATE?0
