(acet-ss-drag-move ...) returns error
Hi all
If I do
(acet-ss-drag-move (ssget) (getpoint "\nGrab a point: "))
I get an error. Is this syntax right, similar to competition?
From https://forum.bricsys.com/discussion/21353/acet-error-init I understand these functions have native support, is that right? I could not find an entry in Help, hence.
You can find information about this function in the LDSP. Note that the prompt argument must be nil. If you supply a string instead, the function will fail because of missing sub-functions.
Thanks Roy
F1-Help points to here.
LDSP says:
(acet-ss-drag-move sset refPt prompt highlight)So I would expect...
(acet-ss-drag-move (ssget) (getpoint "\nGrab a point: ") "Ola..." T)... not to return:
; error : no function definition <STR_POS_SET> ; expected FUNCTION at [eval]I noticed that
highlightatTornildoesn't make a difference. So(acet-ss-drag-move (ssget) (getpoint "\nGrab a point: ") nil nil)works fine (for me) with the
nilentry as you suggested.I'll do a support request for this.
Dear Wiebe,
many thanks ... I will review and fix that defect, thanks also for support request :-)
many greetings !0
