lofting cross section issues
Hi Team,
I have been trying to use loft to create a solid. Im using 10 closed polyline cross section to loft and when I initially do it the loft works and the solid comes out exactly how I had hoped. my issue comes from when I save, exit and then go back into the file the solid has gone whacky. I have attached a picture of it. In the picture I show the cross sections I am trying to use, the lofted solid before exiting the drawing and then the lofted solid after I have save and re entered the drawing. any suggestions? thanks.
When you run the _REDSKINFO command, does the render engine report a good validation and status check of your video system?
Hi Richard not sure whats a good outcome would you mind having a look below?
REDSDKINFO
RedSDK version: 4.2 (build 4)
RenderUsingHardware: Hybrid hardware/software mode with preferred hardware rendering.
OpenGL window creation succeeded.
Operating system: Win_ten64
Desktop composition (Aero) is enabled.
Local GPU:
GPU information:
name: 'NVIDIA GeForce GTX 960M'
chipset: 'GM107'
class: 'HW_NVIDIA_G400'
asicID: '0x139b'
vendorID: '0x10de'
recommended driver: 'Operating system proprietary graphic driver'
Installed driver:
driver: 'NVIDIA Forceware 398.82'
dll version: ''
This driver is newer than all internal known revisions.
validation: 'Ok, newer'
Local GPU:
GPU information:
name: 'Unknown INTEL graphics adapter'
chipset: ''
class: 'HW_INTEL_GENERIC'
asicID: '0x191b'
vendorID: '0x8086'
recommended driver: unknown
Installed driver:
driver: ''
dll version: ''
validation: ' ==========>>>>> No driver installed <<<<<=========='
Selected GPU (created for GPU check):
Chipset: HW_NVIDIA_G400
Vendor: NVIDIA Corporation ( IsNVidia )
OpenGL version: 4.6.0 NVIDIA 398.82
Renderer: GeForce GTX 960M/PCIe/SSE20 -
Could you post the original DWG with the "rings" and the lofted body? Could help narrow down the cause.
I would speculate that what you're seeing is an artifact of your graphic card. GeForce cards are great for day to day use and super for gaming; I have one in my gaming rig now. But the GTX cards are optimized for speed and sometimes fall over in CAD applications. There's a discussion thread over here with some comparison pics of GeForce versus Quadro cards.
