Command "bimsection" versus "_SECTIONPLANETOBLOCK"
What are the main differences between these commands?
Both need a "sectionobject" and create a 2D-drawing;
"bimsection" does not use a dialogue but "sectionplanetoblock" needs a dialogue.
Are they really the same for 98%??
Thanks for advice!
The main difference is that a BimSection creates a block in a drawing which is defined by the Destination File property of the BimSection. In this drawing a paperspace viewport is created and added as a sheetview in a sheet of a sheetSet. All other BimSections in the same model are added to the same sheetset.
OK, Louis, thanks.
So the main steps "from Sectionobject to 2D-drawing" are the same.
@Peter2 said:
So the main steps "from Sectionobject to 2D-drawing" are the same.Correct. Another important difference which I forgot to mention is that a link is created between the section entity and the section block.
