Hide/delete some items in array
I need to hide/delete a few items in the polar array, is it possible?
I don't think so but that would be great !
Example :
An Array of Columns in Buildings where some of them
get replaced by Staircase Cores.So to be able to keep the Parametric Array and just
deactivate some of its Components.0 -
I read that in AutoCAD it is possible to select individual item in the array by clicking Ctrl and press Del key to delete. BricsCAD is same but has bug I think, I can only select just a few items, not all items are allowed to select.
Uh, Thanks for that.
I tested in Shape for Mac.
It works for me. I can select individual Instances and delete them.
And I can still edit the Array and do changes like adding Rows or
change Distances. And select and delete more Instances.There is even a Replace, but I don't get the Tool Workflow and Timing
to get the result I want.
