Hide/delete some items in array
I need to hide/delete a few items in the polar array, is it possible?
  • I don't think so but that would be great !
    Example :
    An Array of Columns in Buildings where some of them
    get replaced by Staircase Cores.
    So to be able to keep the Parametric Array and just
    deactivate some of its Components.
  • I read that in AutoCAD it is possible to select individual item in the array by clicking Ctrl and press Del key to delete. BricsCAD is same but has bug I think, I can only select just a few items, not all items are allowed to select. :/
  • Uh, Thanks for that.
    I tested in Shape for Mac.
    It works for me. I can select individual Instances and delete them.
    And I can still edit the Array and do changes like adding Rows or
    change Distances. And select and delete more Instances.
    There is even a Replace, but I don't get the Tool Workflow and Timing
    to get the result I want.
