Hatching problem in V19
in 2D Drafting
Hi, I just installed V19 and then continued with a drawing I started in V18. I've noticed that the hatching is not working properly. I normally use the button to pick a point in the boundary and it works fine, but in V19 its not selecting the boundary correctly. When I then open the same drawing in V18 and do the hatching, there's no problem. Is there some new setting that has to be adjusted in V19?
A hatch problem that existed in V19.1.06 has been fixed in V19.1.07.
If you experience this hatch problem with V19.1.07, we would be grateful if you filed a support request and attached a sample drawing that allows to reproduce the problem.Best regards,
Hans0 -
Thanks, I'll install the update & check.
