Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Hatching problem in V19
Hi, I just installed V19 and then continued with a drawing I started in V18. I've noticed that the hatching is not working properly. I normally use the button to pick a point in the boundary and it works fine, but in V19 its not selecting the boundary correctly. When I then open the same drawing in V18 and do the hatching, there's no problem. Is there some new setting that has to be adjusted in V19?
  • A hatch problem that existed in V19.1.06 has been fixed in V19.1.07.
    If you experience this hatch problem with V19.1.07, we would be grateful if you filed a support request and attached a sample drawing that allows to reproduce the problem.
    Best regards,
    Hans
  • Thanks, I'll install the update & check.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
