UI Colours and High Contrast Themes
in Other
In V19 it seems that some of the UI backgrounds are hardcoded white, while the text colour changes with Window's theme.
If you switch to a high contrast theme in Windows (white text, black background), BricsCAD now shows white text on a white background, which is not terribly useful.
If background colours are set fixed, the text colour must be too.
Same in Linux (Manjaro) here with V18.
I have KDE and used to have a dark theme.
Parts of the UI works against theme mode, part of
the UI follow the theme, while the Text never does
and may not be visible at all.0
