UI Colours and High Contrast Themes
In V19 it seems that some of the UI backgrounds are hardcoded white, while the text colour changes with Window's theme.
If you switch to a high contrast theme in Windows (white text, black background), BricsCAD now shows white text on a white background, which is not terribly useful.
If background colours are set fixed, the text colour must be too.
  • Same in Linux (Manjaro) here with V18.
    I have KDE and used to have a dark theme.
    Parts of the UI works against theme mode, part of
    the UI follow the theme, while the Text never does
    and may not be visible at all.
