DXF files
I am currently using Bricscad 18.2.14 but have Autocad 2012 also in the office on other computers. I have found that DXF files created by Bricscad will not load into Autocad or Civilcad 7.2 (surveying software).
The DWG file will upload fine but fails on the DXF.
I think it's best to create a SR with the file attached so we can try to reproduce this behaviour.
Mathieu, Is there a variable or setting to set the DXF version to 2010 for example as the default 2018 DXF version may have been the issue.
How do you create your DXFs? Both with the _SaveAs and the _DxfOut command the user can specify the DXF version.
