Error when executing Lisp file
HI,
I found a 3d stretch lisp file online and I loaded it through Appload command, but when I go to run it this error message comes up "error : system variable not available : subobjselectionmode" I dont know much about lisp and resolving these types of errors. Any help would be appreciated. Thanks!
Hi Eric, where did you find the code?
cadstudio
Apparently, this is the code:
;3Dstretch - stretch 3D model's faces in any direction ;CAD Studio, 2017 - www.cadstudio.cz www.cadforum.cz (defun C:3DSTRETCH (/ cmde sosm ss wp1 wp2 sp1 sp2) (setq cmde (getvar "cmdecho")) (setvar "cmdecho" 0) (setq sosm (getvar "subobjselectionmode")) (setvar "subobjselectionmode" 3) (princ "\nWindow-select faces to stretch") (and (setq wp1 (getpoint "\nPick the first window corner: ")) (setq wp2 (getcorner wp1 "\nPick the second window corner: ")) (setq ss (ssget "_W:V" wp1 wp2)) (not (command "_SELECT" ss ; simulated (setq sp1 (getpoint "\nPick the first 3Dstretch point (from) or <displacement>: ")) (if sp1 (setq sp2 (getpoint sp1 "\nPick the second 3Dstretch point (to): ")) (setq sp1 '(0 0 0) sp2 (getpoint sp1 "\nSpecify displacement <0.0,0.0,0.0>: ")) ) (if (not sp2) (setq sp2 sp1)) nil)) ; cancel it (command "_move" ss "" sp1 sp2 "_stretch" "_c" wp1 wp2 "_r" "_p" "" sp1 sp2 ) ) (setvar "subobjselectionmode" sosm) (setvar "cmdecho" cmde) (princ) )A workaround for selecting faces could be setting selectionmodes to 2, but pressing ctrl to prevent selecting solids does not work off course. I am really curious if someone else knows a solution.
By the way, should (ssget "W:V" ...) be supported?
I checked the code with mine and yes it is the same.
Thanks for looking into this for me.
Maybe there is no need for Lisp code. Depending on the license the _DmMove command can be used.
Thanks Roy!
It took me a while to figure out but it seems to work. I need to press "ctrl." before I finalize the selection window.
