Sweep twist angle
I created a long, thin, straight strip and was able to twist it 3600 degrees. I then created a strip in the shape of a hoop, whose ends almost met. When I ran DMTWIST on it, and a bend of 3600 degrees, the command didn't do anything. When I gave it a twist of 90 degrees, it produced unpredictable results, as shown in the attached screen shot.. I think the BricsCAD version is only good for twisting straight objects.
Thanks, Jim
but I was talking abut the twist angle of the sweep command.0 -
Maybe there are other ways to get to the result (?)
Like Bending 1 or 2 Helixes and Extruding Along Path
or copying and rotating a few Profiles and Revolve,
Extrude, Sweep, Loft and such things, using all their
options (?)0 -
For BricsCAD issues you're best to raise a support request. Look for SR92431 in the release notes of a future update.
CAD Concepts0
