Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Sweep twist angle
edited June 2019 in 3D Tips and Tricks
Seems I can't get twist angle more than 360? In AutoCAD there is no limit - this is with twist angle 3500:
  • I created a long, thin, straight strip and was able to twist it 3600 degrees. I then created a strip in the shape of a hoop, whose ends almost met. When I ran DMTWIST on it, and a bend of 3600 degrees, the command didn't do anything. When I gave it a twist of 90 degrees, it produced unpredictable results, as shown in the attached screen shot.. I think the BricsCAD version is only good for twisting straight objects.
    641 x 538 - 22K
  • Thanks, Jim
    but I was talking abut the twist angle of the sweep command.
  • Maybe there are other ways to get to the result (?)
    Like Bending 1 or 2 Helixes and Extruding Along Path
    or copying and rotating a few Profiles and Revolve,
    Extrude, Sweep, Loft and such things, using all their
    options (?)
  • For BricsCAD issues you're best to raise a support request. Look for SR92431 in the release notes of a future update.
    Regards,
    Jason Bourhill
    CAD Concepts
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
