Request: Apply Date Routine as MM/DD/YY
Could someone point to a LISP routine with a format similar or able to be modified per the subject line?
Thanks,
Clinton Hill
  • Roy Klein Gebbinck
    edited July 2019
    Your request is a bit vague. But perhaps this?:
    (menucmd "M=$(edtime,$(getvar,date),MO/DD/YY)")
  • My pardons, Roy.
    I appreciate your offering. I am little rusty and need to revisit basic customization: Might this code be assigned to a palette or toolbar button?
    I was searching for an existing LISP program that would would allow the user to select an attribute value an existing value be replaced by the current date with a mouse click.
    edited July 2019
    (defun c:DateToAtt ( / doc enm sel)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (vla-endundomark doc)
      (vla-startundomark doc)
      (if
        (and
          (setq sel (nentsel))
          (= 2 (length sel)) ; Avoid changing nested attributes.
          (setq enm (car sel))
          (= "ATTRIB" (vle-entget 0 enm))
        (vle-entmod 1 enm (menucmd "M=$(edtime,$(getvar,date),MO/DD/YY)"))
      (princ)
    EDIT: Added a check to avoid changing nested attributes.
  • Have you considered using a FIELD? Depending on your requirements this would be a non-programming method to achieve the same.
    CAD Concepts
    CAD Concepts
    Take care using the FIELD option. The **FIELDEVAL **system variable may cause the date to auto-update, which may not be suitable if you wanted a static string.
  • Kerry Brown
    edited July 2019
    Sorry, I tried, but I can't help myself ... this is a pet peeve of mine
    https://xkcd.com/1179/
  • chillme1
    edited July 2019
    Excellent idea: Fields are very powerful. In this case, I prefer a static value. I appreciate your concern.
    I was hoping someone might have a routine in their customization arsenal.
  • chillme1
    edited July 2019
    I hope I can rise to the LISP programming challenge through creating this routine.
  • @chillme1 You have perhaps missed my 2nd contribution?
  • Indeed I did, sir !!! I thank you for this generous offering.
    My aim is to refer to your code as a learning tool as well as applying it to daily drawing production.
    Thanks, Roy.
    Clint Hill
