Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Request: Apply Date Routine as MM/DD/YY
Could someone point to a LISP routine with a format similar or able to be modified per the subject line?
Thanks,
Clinton Hill
  • edited July 2019
    Your request is a bit vague. But perhaps this?:
    (menucmd "M=$(edtime,$(getvar,date),MO/DD/YY)")
  • My pardons, Roy.
    I appreciate your offering. I am little rusty and need to revisit basic customization: Might this code be assigned to a palette or toolbar button?
    I was searching for an existing LISP program that would would allow the user to select an attribute value an existing value be replaced by the current date with a mouse click.
  • edited July 2019
    (defun c:DateToAtt ( / doc enm sel)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (vla-endundomark doc)
      (vla-startundomark doc)
      (if
        (and
          (setq sel (nentsel))
          (= 2 (length sel)) ; Avoid changing nested attributes.
          (setq enm (car sel))
          (= "ATTRIB" (vle-entget 0 enm))
        (vle-entmod 1 enm (menucmd "M=$(edtime,$(getvar,date),MO/DD/YY)"))
      (princ)
    EDIT: Added a check to avoid changing nested attributes.
  • Have you considered using a FIELD? Depending on your requirements this would be a non-programming method to achieve the same.
    Regards,
    Jason Bourhill
    CAD Concepts
    Regards,
    Jason Bourhill
    CAD Concepts
    Take care using the FIELD option. The **FIELDEVAL **system variable may cause the date to auto-update, which may not be suitable if you wanted a static string.
    Regards,
  • edited July 2019
    Sorry, I tried, but I can't help myself ... this is a pet peeve of mine
    https://xkcd.com/1179/
  • edited July 2019
    Excellent idea: Fields are very powerful. In this case, I prefer a static value. I appreciate your concern.
    I was hoping someone might have a routine in their customization arsenal.
  • edited July 2019
    I hope I can rise to the LISP programming challenge through creating this routine.
  • @chillme1 You have perhaps missed my 2nd contribution?
  • Indeed I did, sir !!! I thank you for this generous offering.
    My aim is to refer to your code as a learning tool as well as applying it to daily drawing production.
    Thanks, Roy.
    Clint Hill
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
