Load Selection in console ERROR
(setq lst '(1 74678.6 53741.6 0.0))
(setq result
      (vl-string-subst "" ")"
        (vl-string-subst "" "(" (vl-prin1-to-string lst))
Loading this in the Console causes this error
(PRINC)
; error : malformed list on input at [read]
The statement inside the result assignment CAN be loaded sucessfully.
https://gyazo.com/4879dd77b1a94e8f4bbef45489337197
added:
What is the address for the development team so this can be sent direct ( next time )
  • Dear Kerry,
    many thanks for reporting ... I will check this scenario to see what goes wrong.
    "What is the address for the development team so this can be sent direct ( next time )"
    normally, just send us a support request, it will be handled by the support and development team then.
    Where necessary, small dwg file(s) and code snippets can be attached there as well.
    many greetings !
  • Thanks Torsten
    Version 19.2.07 (x64) revision 61634 en_us
    Win 10
  • Dear Kerry,
    thanks for providing the version :smile: I would have asked for this anyway ...
    just checking the problem ...
    more to come & many greetings !
  • Dear Kerry,
    I found and fixed that problem (for V20) ...
    you might bypass the problem by using "Load Selection in BricsCAD", the result is also shown in Console window/panel.
    thanks & greetings !
  • Thanks Torsten.
    I appreciate the effort and attention to detail.
    As an aside, a cleaner solution to the programming purpose was suggested by Roy :
    (vl-string-trim "()" (vl-prin1-to-string lst))
  • Ah, yes ... as we all know, Roy is a real wizard :smile:
    many greetings !
