V19 : Quad Function Settings Needed: Display Optional Commands versus Object Properties
A co-worker using the QUAD in Classic displays only object properties when hovering over an object. My Platinum version defaults to several optional command glyphs / icons when hovering over an object with the QUAD.
QUESTION
Which QUAD setting(s) controls the above behavior?
Thanks,
Clint
You could just deactivate the whole QUAD (tools) functionality from
statusbar by deactivating the QUAD text button.The objects properties for the QUAD are called/controlled "Roll over Tips"
and could be deactivated also.0 -
That helped, Michael. Thanks!
