V19 : Quad Function Settings Needed: Display Optional Commands versus Object Properties
A co-worker using the QUAD in Classic displays only object properties when hovering over an object. My Platinum version defaults to several optional command glyphs / icons when hovering over an object with the QUAD.
QUESTION
Which QUAD setting(s) controls the above behavior?
Thanks,
Clint
  • You could just deactivate the whole QUAD (tools) functionality from
    statusbar by deactivating the QUAD text button.
    The objects properties for the QUAD are called/controlled "Roll over Tips"
    and could be deactivated also.
  • That helped, Michael. Thanks!
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
