3D solids equivalent to Divide
Given 2 solids an unknown distance apart, how would one go about filling the space between them with a certain number of identical solids?
Think of this as two fence posts on the corners of a property and the task is to add X number of additional posts between them WITHOUT KNOWING ANY DISTANCE MEASUREMENTS.
My primitive solution is to draw a line between the original posts, center to center on the XY plane and then use Divide to place evenly spaced points on that line to use as destinations for a copy using the Manipulator's 'r' capability to sweep across the line.
: ARRAYPATH Select entities to array: Entities in set: 1 Select entities to array: Type = Path, Associative = Yes Select path curve: [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit] <eXit>:me Enter path method or [Divide/Measure] <Measure>:d [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit] <eXit>:it Enter number of items along path or [Expression]: <20>: 6 [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit] <eXit>:
There is no path curve. All you have are two solids.
The method I outlined uses a crutch to allow DIVIDE to do the heavy lifting. I'm looking for something that can do it without creating a phony element.
Does such a method exist? That's the question!
When prompted for the total distance pick two points. You only need 1 solid. You may need to align your UCS first.
: ARRAYRECT Select entities to array: Entities in set: 1 Select entities to array: Type = Rectangular, Associative = Yes [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit] <eXit>:r Enter the number of rows or [Expression]: <3>: 1 Enter the distance between rows or [Total/Expression]: <75>: Enter the incrementing elevation between rows or [Expression]: <0>: [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit] <eXit>:col Enter the number of columns or [Expression]: <4>: 6 Enter the distance between columns or [Total/Expression]: <75>: t Enter total distance between start and end columns: <375>: Second point: [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit] <eXit>:
