Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
3D solids equivalent to Divide
Given 2 solids an unknown distance apart, how would one go about filling the space between them with a certain number of identical solids?
Think of this as two fence posts on the corners of a property and the task is to add X number of additional posts between them WITHOUT KNOWING ANY DISTANCE MEASUREMENTS.
My primitive solution is to draw a line between the original posts, center to center on the XY plane and then use Divide to place evenly spaced points on that line to use as destinations for a copy using the Manipulator's 'r' capability to sweep across the line.
  • edited July 2019
    : ARRAYPATH
    Select entities to array:
    Entities in set: 1
    Type = Path,    Associative = Yes
    Select path curve:
    [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit] <eXit>:me
    Enter path method or [Divide/Measure] <Measure>:d
    [ASsociative/Method/Base point/Tangent direction/Items/Rows/Levels/Align items/Z direction/eXit] <eXit>:it
    Enter number of items along path or [Expression]: <20>: 6
  • There is no path curve. All you have are two solids.
    The method I outlined uses a crutch to allow DIVIDE to do the heavy lifting. I'm looking for something that can do it without creating a phony element.
    Does such a method exist? That's the question!
  • When prompted for the total distance pick two points. You only need 1 solid. You may need to align your UCS first.
    : ARRAYRECT
    Entities in set: 1
    Type = Rectangular,    Associative = Yes
    [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit] <eXit>:r
    Enter the number of rows or [Expression]: <3>: 1
    Enter the distance between rows or [Total/Expression]: <75>:
    Enter the incrementing elevation between rows or [Expression]: <0>:
    [ASsociative/Base point/COUnt/Spacing/COLumns/Rows/Levels/eXit] <eXit>:col
    Enter the number of columns or [Expression]: <4>: 6
    Enter the distance between columns or [Total/Expression]: <75>: t
    Enter total distance between start and end columns: <375>:
    Second point:
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
